Activity Forums Adobe Premiere Pro Playback issue
  • Playback issue
    Posted by Tsua Coola on November 21, 2012 at 6:56 am
    I am using premiere pro cs5. I recorded some footage a few years ago and I’m finally ready to edit it however…
    My footage is in .mov files. When I try and import it an error message appears saying: Codec missing or unavailable.
    I convert a file to an .mp4 file and I can now import it, however the preview screen doesn’t play back its just a still image. Audio works though, and if I pause the video and select the clip it updates the frame.
    I tested the .mp4 file with windows movie maker and it seems to work fine.
    Please help me figure this out!
    Tsua Coola replied 13 years, 10 months ago 2 Members · 5 Replies
  • Alex Gerulaitis
    November 21, 2012 at 10:27 am
    Can you make a small sample (under 30-40MB), upload it to Google Drive, Dropbox or a similar service, and post a link here so it could be downloaded and tested?
    Alex Gerulaitis
    Systems Engineer
    DV411 – Los Angeles, CA
  • Tsua Coola
    November 22, 2012 at 12:45 am
    Alright thanks!
    I will upload a video for you to have a look at.
  • Tsua Coola
    November 22, 2012 at 11:42 am
    Hey here is a video in the format I am trying to work with:
    https://ge.tt/4guA78S/v/0
    Thanks.
  • Alex Gerulaitis
    November 24, 2012 at 7:19 am
    The .mov (QuicTime) file is encoded in a very exotic way. The codec shows “HDV 1080i50”, yet QT player shows actual res at 1888×1062 – and plays audio only. Neither Premiere Pro CS5 nor AME can load it: “bad codec”.
    Converted to H.264 1080i50 (1440×1080) using Handbrake, Premiere Pro CS5 crashes importing it; AME reports “unknow error” trying to encode it.
    Converted to WMV using Windows Movie Maker (WMM) into a 1080i29.97, the resulting file plays fine in Premiere Pro. Here it is.
    I am mystified – and don’t have time to work more on it – maybe later. My guess – the file is encoded in an exotic way and even though Handbrake can see it, it encodes it with errors. WMM encodes it successfully, even if with a different frame rate.
    Alex Gerulaitis
    Systems Engineer
  • Tsua Coola
    November 26, 2012 at 10:19 pm
    Thanks so much Alex!!
    I will try concoverting the footage to .WMV files.
    I’ll let you if it works for me.
    Thanks again!
