Activity › Forums › Apple Final Cut Pro Legacy › Playback is fine, but scrubbing makes canvas go red??
  • Playback is fine, but scrubbing makes canvas go red??
    Posted by Josh Evans on January 30, 2006 at 12:48 pm
    When I play my video everything is fine. But when scrubbing through the timeline, the canvas image has a red tint to it, and there is a little white circle with a black cross through it in the top right corner. The image also goes laggy as hell.
    What is going on here?
    cheers
    Jerry Hofmann replied 20 years, 8 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    January 30, 2006 at 1:46 pm
    Sounds like you need to set your playback settings to RGB in the Canvas window. This setting is found in the oval button on the left in the top area of the Canvas.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
