Activity Forums AJA Video Systems playback in PP with pan and scroll is stuttery and jerky
  • playback in PP with pan and scroll is stuttery and jerky
    Posted by Anhtu Vu on November 24, 2012 at 6:55 pm
    The playback of scenes with pan or scroll is jerky/stuttery. I know it’s not the source file as they all play fine in QT or via Avid.
    I’m using Adobe Premiere CS6 with Kona io xt on a Macbook Pro running 10.8.2. My studio’s rig display the same behavior, Z800 win 7 with CS6 and Kona 3G. I use a broadcast monitor with HD-SDI.
    This is most likely a Premiere/AJA integration issue.
    I tried different playback settings in PP, they all yield the same result…for example, this particular file is in 1080psf @23.976, codec is DnxHD, i have the playback set at, 1080p23.98 custom with DnxHD codec. playback is still stuttery.
    Any idea ??? Thx
    Anhtu Vu replied 13 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
