Activity Forums Adobe After Effects playback help
  • playback help
    Posted by Matthew Preis on March 1, 2007 at 4:22 pm
    I am trying to do a Ram preview. I keep getting a message saying ram need 2 or more frames for playback, but I have my whole comp selected in the work area. Anyone have this happen? know how to fix it
    Kevin Camp replied 19 years, 6 months ago 4 Members · 4 Replies
  • Matthew Preis
    March 1, 2007 at 4:48 pm
    double checked, it’s 15 seconds, still won’t playback.
  • Iancorey
    March 1, 2007 at 6:06 pm
    You may have “Always Preview This View” selected. And maybe that view has no frames. Bottom left of the comp window. Looks like a teevee screen.
  • Tony Kloiber
    March 1, 2007 at 6:37 pm
    If your saying that, you have been working with this setup for sometime and it worked in the past and your on a mac and you haven’t change your preview settings and you don’t have other comps open and your work area is set to the length you want to preview, then purge all (its a menu choice) and try the ram preview again.
    TonyTony
  • Kevin Camp
    March 1, 2007 at 9:17 pm
    in time controls, if the ‘ram preview options’ (versus the ‘shift-ram preview options’) are set to start the ram preview ‘from current time’ (check box option), and you are on the last frame of you comp, you will get this error.
    uncheck the option or go to a different frame in the comp and ram preview
