Activity Forums Apple Final Cut Pro Legacy Playback Control – Frame Offset
  • Playback Control – Frame Offset
    Posted by Ric Christoferson on May 8, 2007 at 6:34 pm
    I have been using 7 frames as my offset for the past 4 years… seems to work well..
    no lipsyc complaints…
    I’m curious… Is there a standard setting for this and what is everyone else using and
    why ???
    thanks for your reply..
    Martin Baker replied 19 years, 4 months ago 4 Members · 4 Replies
  • Bbalser
    May 8, 2007 at 6:49 pm
    It’s mostly a capture setting and depends on what you’re capturing from.
  • John Pale
    May 8, 2007 at 7:44 pm
    This setting is there to compensate for the delay in monitoring through firewire devices, which is generally a few frames.
    If you are using a capture card, such as the Kona or Decklink, this should be set to 0, as there is no latency.
    This really doesnt have to do with lip sync, it has to do with the canvas being in sync with the NTSC/PAL monitor (it delays your computer, so the canvas and the video monitor show the same image)
  • John Pale
    May 8, 2007 at 7:50 pm
    Compensating for Video Latency by Specifying a Frame Offset
    No matter what signal format you use for external monitoring, all digital video and
    audio interfaces (including FireWire) introduce inherent processing delays (known as
    latency) to signals sent out of the computer. External video and audio coming from the
    built-in FireWire port or third-party interface may be several frames later than the video
    on your computer display (in the Viewer or Canvas). The latency, or offset, between
    different devices can make precise editing difficult.
    By changing the frame offset value in Final Cut Pro, you can compensate for the delay
    between your computer display and external video and audio outputs. Frame offset is
    active only when your sequence real-time effects are handled by Final Cut Pro. For
    information about setting the Effects Handling tab of the System Settings window, see
    Volume III, Chapter 23,
  • Martin Baker
    May 9, 2007 at 6:33 pm
    In my experience AJA Kona is 0 frames but Decklink range is 4 frames. I asked on the Blackmagic booth at NAB why there’s a 4 frame delay but the guy didn’t know.
    Martin
    Digital Heaven, London UK
    Unique plug-ins and tools for Apple Pro Apps
    Avid2FCP
    For Avid editors learning FCP
