Activity Forums Apple Final Cut Pro Legacy Playback audio sync
  • Playback audio sync
    Posted by Wojtek Jezowski on April 19, 2011 at 2:45 pm
    Ive seen many posts about syncing issues in FC but I couldn’t find something that is happening to me.
    During edit without an external video and audio monitor there seems to be an offset between audio and video – around 1-2 frames.
    For example I have a break in my sequence. After that an interview clip. When the playhead reaches it I cam clearly tell that the audio is being played first instead of audio and video at the same time. I thought at first that maybe i trimmed it wrong but both video and audio clips are matched up and begin at the same time.
    What’s funny is that when i scrub through the clip frame by frame the audio and video are displayed at the same time but it looks as if the audio is offset by 2 frames. When I move the clip, it is in sync while scrubbing but is out of sync when in playback.
    This doesn’t happen on a different mac I use for editing so there must be something wrong. Its a 2x2ghz dual core mac pr with 8gb ram. I just completed a fresh install of snow leopard and fcs3. Everything is up to date.
    Please help. Its annoying 🙂
    Wojtek Jezowski
    Wojtek Jezowski replied 15 years, 4 months ago 2 Members · 2 Replies
  • Michael Gissing
    April 19, 2011 at 10:54 pm
    Are you using a Kona card and are the drivers up to date. I had a sync offset issue with playback that was fixed by updating the Kona software.
  • Wojtek Jezowski
    April 20, 2011 at 11:29 am
    Nope. I have a Blackmagic deklink SDI but the problems started before I installed it this week.
    Wojtek Jezowski
