Activity › Forums › VEGAS Pro › Play stopped working
  • Play stopped working
    Posted by Dan Sherman on March 30, 2019 at 7:31 pm
    Neither space bar nor Shuttle Pro will play veg files on timeline. No response. Options/preferences seems OK. Any ideas.
    Graham Bernard replied 7 years, 6 months ago 3 Members · 2 Replies
  • George Dean
    March 30, 2019 at 10:25 pm
    Hi Dan,
    That’s not much to go on! How about some details, history, version and build number, system setup, some details about your project, FX’s and effects you may be using, working in 8 bit or 32 bit?
    Have you done a full reset? Hold down the ‘Ctrl+Shift’ keys while double left clicking on the Vegas Pro desktop shortcut. When the small window pops up, check the box ‘Delete all cached application data’, then left click on “Yes’. This will reset Vegas to it’s original installation settings and delete the pesky cached application data that builds up and will sometimes cause Vegas to do strange things.
    Best Regards……George
  • Graham Bernard
    March 31, 2019 at 8:21 am
    [George Dean] “That’s not much to go on!” George, I agree.
    OK, I’m starting to read reports from Users that this issue is gathering pace, again. We’ve been here before. I’m getting a convergence between this issue AND the NLE’s need for its time clock referencing just where and what it should do back on the Timeline. So, my fixes, without “knowing” the programming on of this has been to:
    1] Change the Audio Device Settings away from my External PreSonus AudioBox.
    2] Disconnect AND reconnect the USB plug from the PSAB.
    * Grazie
    Cameras: Canon XF300 + PowerShot SX60HS Bridge
