Activity Forums Apple Final Cut Pro Legacy Play: Rate 2 Not Available by Default?
  • Play: Rate 2 Not Available by Default?
    Posted by Brad L. on December 15, 2005 at 11:29 pm
    Am I missing something, or is every single copy of FCP installed not able to use CNTL + F8 by default? Seems like there are a couple of other hardcoded OS X shortcuts that must be re-assigned to be used as well. Dashboard and Expose can be re-assigned in the OS but I could not find a way to re-assign Menu Extras (Control + F8), Menu Bar (Control + F2) and Dock (Control + F3) all of which are FCP shortcuts by default.
    Brad L. replied 20 years, 8 months ago 2 Members · 2 Replies
  • Nick Meyers
    December 16, 2005 at 7:38 am
    go to system prefs > keyboard & mouse > keyboard shortcuts.
    there you can turn off the system’s shortcuts that conflict with FCP’s
    cheers,
    nick
  • Brad L.
    December 16, 2005 at 2:33 pm
    Sweet. Thanks Nick. I had been there before but had forgot all about it.
    There are more than a dozen that conflict. They should make an option within Final Cut Pro to give priority to application shortcuts so you don’t have to disable so many OS ones universally.
