Activity › Forums › Adobe Premiere Pro › play in to out
play in to out
Posted by Nils Knibbe on November 27, 2011 at 8:56 pmHi all,
I can’t play a clip in the source monitor from the inpoint to the outpoint without preroll. In keyboard shortcuts it say ctrl space will do this, and shift space will add two seconds before and after the in- and outpoints. Doesn’t work however.
Anyone have a solution for this?Thanks
NilsBendito Jordana replied 10 years, 2 months ago 5 Members · 9 Replies -
Ann Bens
November 27, 2011 at 10:58 pmCtrl+space will play from playhead to outpoint.
If you want to play from inpoint to outpoint you need to set a keyboard shortcut.———————————————–
Adobe Certified Expert Premiere Pro
Adobe Community Professional -
Nils Knibbe
November 27, 2011 at 11:28 pmHi Ann
Thanks for your answer. The shortcut to play in to out is ctrl space, I think thats default. Problem is that it includes two seconds pre- and postroll, wich I don’t want. Shift space is set for play in to out with pre and postroll. Both combinations perform excactly the same action.Thanks
Nils -
Ann Bens
November 27, 2011 at 11:33 pmNo it’s not, check the shortcuts in Edit/Keyboard Shortcuts.
Nils Knibbe
November 27, 2011 at 11:38 pmHmm, I’ll check it again, but I’m pretty sure it is set to ctrl space in my setup, but I changed quite a few shortcuts.
Thanks again!
Nils
Nils Knibbe
November 28, 2011 at 1:08 pm
These are the settings I use for reviewing the trimmed clip before placing it on the timeline.
So ctrl space should play exactly between the in and outpoint. Shift space should add two seconds before and after.
Both functions do exactly the same however, both in the source panel and the timeline.
There is a button for playing in to out, I just hoped it would be possible using a shortcut.Thanks
Nils -
Kevin Monahan
November 29, 2011 at 9:25 pmI just assigned a shortcut for playing in to out. It works perfectly, as does Shift+Space. Maybe trash your preferences?
https://blogs.adobe.com/genesisproject/2011/02/premiere-pro-cs5-maintenance-two-great-tips.html
Kevin Monahan
Sr. Content and Community Lead
Adobe After Effects
Adobe Premiere Pro
Adobe Systems, Inc.
Follow Me on Twitter! -
Nils Knibbe
November 30, 2011 at 11:53 amHi Kavin,
thanks for the suggestion, I trashed the preferences and re-assigned the shortcut but it still behaves the same.
Pity but not a disaster, I can still use the button.Thanks for your help!
Nils
Bendito Jordana
July 7, 2016 at 8:35 pmSounds like your preroll & postroll settings (in Preferences) are set to 0.
