Activity Forums Adobe Premiere Pro Play In – Out
  • Play In – Out
    Posted by Abe Froman on February 17, 2018 at 3:03 am
    Our shop is transitioning from Avid to Premiere Pro, and there is a function for which I’m trying to find the equivalent. On Avid, you can mark IN and OUT on your sequence, and a mark on your b-roll (either an IN or OUT). Then you can play IN to OUT to preview what part of the clip will be used in the timeline. Can you do anything like that on Premiere?
    Jorn Bergmans replied 8 years, 7 months ago 2 Members · 1 Reply
  • Jorn Bergmans
    February 19, 2018 at 2:22 pm
    There is an option in Premiere called ‘Play In to Out’. There’s also an option to play around in-out with a two second preroll/postroll.
    The default shortcut for Premiere keybindings is ALT+K and play around is SHIFT+SPACE
    The default shortcut for FCP7 keys is SHIFT+\ and play around is SHIFT+SPACE
    These will always play the currently active window, no matter if that is source, program, ref or timeline. Anything that can contain in- and outpoints will have a play in to out option.
