Activity Forums Adobe Premiere Pro Play Head return to previous position on stop?
  • Play Head return to previous position on stop?
    Posted by Tom McCaffrey on February 5, 2021 at 5:15 am
    HI – I’m new to Premiere but have extensive experience using Sony Vegas. I can’t figure out how to do a very simple thing: In Premiere, like in Vegas, the default for resetting the play head is that when you hit play and then stop, hitting play again starts at the location where you stopped, which is frankly not that useful (e.g. if your play head is initially at the 2:00 minute mark and you play for 15 seconds and hit stop, next time it will play at 2:15 – UGH!!). Vegas has a preference option where you can change that behavior so that when you hit play and then stop, it returns the play head to the position it was before you hit play – for example, if your play head is at exactly the 2:00 minute mark and you hit play and then play for 15 seconds before stopping, the play head will return back to exactly the 2:00 minute mark. How can you get Premiere to do exactly this? I’m doing an audio mix for an entire feature-length film so I do NOT want to go to the trouble of setting in and out points for every place that I need to listen back from, there are literally thousands of times I will need to do that. THANKS!!
    Vik Kum replied 3 years, 4 months ago 4 Members · 3 Replies
  • Karen Lee
    February 5, 2021 at 2:24 pm
    Have you used the loop function? Here’s a vid that explains it: https://www.youtube.com/watch?v=69Jn1QWadRw
    You’ll have to hit pause because a looped section keeps replaying until you intervene.
    I’m not sure you can perform the operation exactly as you describe in SV, perhaps someone else knows of a way.
  • Vũ Thái Hưng
    April 30, 2023 at 3:32 pm
    edit>preferences>keyboardshorcut> search play around> change to space button, delete ctrl+k
    next step: edit>preferences>playback> chỉnh preroll là 0, postroll là 60
  • Vik Kum
    May 2, 2023 at 4:57 pm
    As in….find the entry called PLAY AROUND…and then set spacebar as its shortcut ? And Ctrl+K…. while i greatly appreciate your trying to help….but you seem to be answering in shortcut language instead of a full sentence. Makes it difficult to decipher.
