Activity Forums Adobe After Effects Expressions Play first 10 frames of a precomp
  • Play first 10 frames of a precomp
    Posted by Darryl Torke on March 15, 2014 at 4:05 pm
    I have a multiple precomps inside a main composition and would like each of the precomps to do the following behaviour:
    -play the first 10 frames of the precomp.
    -then display and hold a random frame between frames 11-30 of the precomp
    For practical purposes the first 10 frames is a flower animation opening up, but then I would like to design different random configurations of the flowers as the last frame.
    Is this possible using time-remap and expressions?
    Thank you for your time.
    Darryl Torke replied 12 years, 5 months ago 2 Members · 2 Replies
  • Dan Ebberts
    March 15, 2014 at 4:28 pm
    This should work. Note that the way you described it, frame 10 will never play (first 10 frames would be 0 through 9). I’m not sure if that was intentional.
    if (timeToFrames(time) < 10){
    value;
    }else{
    seedRandom(index,true);
    framesToTime(Math.floor(random(11,30)));
    Dan
  • Darryl Torke
    March 15, 2014 at 4:38 pm
    Ah, thanks this works! You were right it was not intentional to exclude frame 10, thanks for mentioning that or I would of been stupefied.
