Play alpha and RGB at the same time
Is it possible to play alpha AND RGB at the same time on two different outputs ? (If the hardware allows, like a Quadro SDI output card which has four different SDI outputs).
I am hoping to use Premiere CS5 or AE to key graphics over a live video signal through a Grass Valley switcher. I know it would be feasible using a chroma key but obviously an alpha channel gives a better key.
Pierre Corbeil
