Activity Forums Adobe Encore DVD Play All…except it doesn’t.
  • Play All…except it doesn’t.
    Posted by David on January 27, 2006 at 7:04 pm
    Hey folks,
    So here’s a really weird problem I’m having: I have several timelines in a DVD project that, from the menu, can either be played individually or all at once. All of the individual playbacks work fine; the problem comes when the viewer selects “Play All.” The first three clips (out of about eight) play fine, and then it kicks back to the menu. I’ve checked all of the end actions for all the timelines and they are all correct. Any ideas as to why this might happen?
    – David Pagano
    Aanarav Sareen replied 20 years, 7 months ago 3 Members · 2 Replies
  • Joe Bowden
    January 27, 2006 at 7:31 pm
    What mechanism are you using to Play All? End actions, or a playlist? Are you using any overrides?
  • Aanarav Sareen
    January 27, 2006 at 7:32 pm
    Can you give us a detailed description of your project, including the end action and override settings for each of the timelines?
