Activity › Forums › Adobe After Effects › Plastic Faces
  • Jason Mettler
    February 3, 2011 at 4:26 am
    For starters, I would try making a displacement map with the original face. Then I’d add a light and mess with the material options of the layer.
    Seems to me there will be several ways to acheive what you want to do.
  • Tudor “ted” jelescu
    February 3, 2011 at 7:47 am
    Is it shiny plastic or matte finish? If you can re-shoot the face (or if you did not shoot it yet) then try to apply some heavy makeup – to make the skin tones uniform and give the face an un-natural look. If it’s shiny plastic you’re after, use some sun tanning lotion (a pretty oily one) to give it highlights. The light is also very important- try to match the same feeling that the plastic action figure has.
    In AE- you can apply the Remove Grain filter to smooth out the skin.
    Tudor “Ted” Jelescu
    Senior VFX Artist
