Activity › Forums › Apple Final Cut Pro Legacy › plasma screen and DVD from an HDV setup in fcp
  • plasma screen and DVD from an HDV setup in fcp
    Posted by Jim Finn on March 25, 2007 at 3:59 am
    I just edited an HDV short and want to put it widescreen on a dvd. If i play it on an HD plasma screen, will it cover the whole screen or window box inside the DV box in. Do i need an HD DVD burner? I hope not.
    yours, jim
    macbook pro intel dual
    Sony HDV-V1U 24p
    Walter Biscardi replied 19 years, 6 months ago 3 Members · 2 Replies
  • 13 Create COW Profile Image
    13
    March 25, 2007 at 5:54 am
    Unless it is a short enough video you will need a HD-DVD burner to make an HD-DVD, ether way you will need a HD-DVD player to play a HD DVD. However you can make a standard definition from your HDV video by sending it through compressor (you are on a mac so I assume you use FCP, DVD SP & Compressor) When you build the DVD in DVD SP as long as you set it to 16×9 it will play wide screen on a widescreen TV.
    A cheeper and easier way to show it in HD would be to get an Apple TV and convert your video for that, the Apple TV supports 720p
  • Walter Biscardi
    March 25, 2007 at 11:29 am
    [gnomebard] “If i play it on an HD plasma screen, will it cover the whole screen or window box inside the DV box in. Do i need an HD DVD burner? I hope not.”
    In DVD Studio Pro just set up a 16:9 DVD. On a widescreen it will fill the screen, on a 4:3 TV it will be letterboxed. This will still be an SD DVD, but it will fill the screen.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
