Activity › Forums › Apple Final Cut Pro Legacy › Plasma on LCD
  • Margus Voll
    October 10, 2007 at 7:15 am
    i had a mistake on last subject 🙂
  • Walter Biscardi
    October 10, 2007 at 9:04 am
    Panasonic Pro Plasma series. We have two of them. Viewing angle, color reproduction and blacks reproduction exceed anything you can get on LCD.
    Anything on this page will work.
    https://www.panasonic.com/business/plasma/plasmas.asp
    http://www.whplatts.com is who I buy from as they are a pro Panny dealer and they have some of the best prices on them.
    We run a 50″ and 42″ in our shop.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Chris Poisson
    October 10, 2007 at 3:46 pm
    Hey Walter,
    I looked up those monitors am amazed how affordable they are. Question, how does SD look on them, does it do it 1:1 or scale it? Or both?
    Have a wonderful day.
  • Walter Biscardi
    October 10, 2007 at 5:02 pm
    [Chris Poisson] ”
    I looked up those monitors am amazed how affordable they are. Question, how does SD look on them, does it do it 1:1 or scale it? Or both?”
    Yes, extremely affordable. Decent job of SD, but not the best. These are HD monitors first and foremost. If you run a lot of SD in 4:3 ratio, you will get a burn in image of the black along the left and right. This will eventually burn its way out, but I would not use this as a primary 4:3 SD monitor.
    No 1:1 scaling. The TV Logic displays have this and they are absolutely stunning in both HD and SD. Much more expensive though.
  • Chris Poisson
    October 10, 2007 at 5:08 pm
    Good info Walter, makes sense. But hey, not a bad TV for the family room I would think too! Thanks for the info.
  • Walter Biscardi
    October 10, 2007 at 5:21 pm
    [Chris Poisson] “Good info Walter, makes sense. But hey, not a bad TV for the family room I would think too! Thanks for the info.”
    Definitely a great TV for the home and it’s cheaper than what you’ll get in a store. Why? Because there’s no tuner, it’s just a display. But since we all use Cable TV boxes and Satellite Boxes, who needs a built in tuner? I know several folks who have these in their homes after seeing what they look like here. Nintendo Wii looks fantastic on it! 🙂
    Oh and for regular SD TV viewing, I put the screen into Justification mode. Looks good and fills the frame so I don’t get burn-in.
  • Chris Poisson
    October 10, 2007 at 6:34 pm
    Cool! Yes, that’s what I thought about the tuner etc.
