Activity › Forums › Adobe After Effects › “Plasma” help…recreating an effect (3 REF PICS ATTACHED)
Posted by Joey Morelli on January 22, 2007 at 12:19 amHello,
I am stumped and I have a client breathing down my neck 🙁 I am looking for help on how to achieve this “plasma” fractal effect and animate it in After Effects. A plug-in, technique, etc. I already got suggestions for Particular, but it does not look like this (unless someone can point me to a tutorial). Here’s the effect I am being asked to recreate (the client used it from stock photography for their print ad):
I have posted this in 4 forums and nobody has come close. Anything would be greatly appreciated.
Thank you in advance
– Joey
Michael Szalapski replied 19 years, 8 months ago 7 Members · 7 Replies -
Ben The camera guy
January 22, 2007 at 4:49 amHey, what you may wanna try is a few instances of advanced lightning, followed with a vector blur to make it look wishy washy…add a bit of a glow to it and you should be getting somewhere…
Mylenium
January 22, 2007 at 6:31 amThe lower two pictures are based on “strange attractors”. There is a free plugin called AEFlame that can create a subset of this type of effect. Other than that you may try Ben’s suggestions or my tips from a few days ago. In case of your radial spiky things, you should also consider builting one such spike/ beam and then clone it a bunch of times. If you use low opacity and Screen or Add blendmode, you could easily create something similar. Some kind of soft wobbly motion could then be introduced by displacement effects like Turbulent Displace.
Mylenium
[Pour Myl
Graham Quince
January 22, 2007 at 9:07 amHi
Seeing as you’re up against it and this artwork looks like it was create from many layered photoshop-ing…have you considered cheating. Check out the liquify effects and use it to animate these stills – You’ll get your movement and won’t have to worry about matching the look.
I’ve had a similar client request in the past and it’s a headache because it’s impossible to recreate someone else’s artwork and then animate it.
Good luck
Graham
https://www.quinceweb.com – web design
https://www.shiveringcactus.bravehost.com – Free FX for amateur films -
Majorasshole
January 22, 2007 at 12:29 pmfractal noise set to a nice round bulbous setting and then set to “invert” gets webby inverted shapes like the bottom one. And yes it looks like a very smooth version of the strage attractors fractal.
Majorasshole
January 22, 2007 at 12:41 pmits not impossible, it’s just time consuming and therefore expensive. If they are breathing down your neck so you don’t have time to do it carefully and the right way, give them the classic choice:
Quick, Cheap or Good…Pick 2
it’s classic because it’s true
Mike Wheeler
January 22, 2007 at 3:17 pmHave you tried using “Wondertouch Particle Illusion”? There are some things in that program that you might be able to play with in AE to get the effect you are looking for..
Michael Szalapski
January 24, 2007 at 9:07 pmHere is an example of a very beautiful 4d fractal created with Trapcode’s particular 4d Fractal
Another option would be to create many layers using Wondertouch’s ParticleIllusion
One of those images could be recreated using many instances of Trapcode’s 3d stroke.
Trapcode’s Particular has a preset (called organic lines, I think) that would start you on the road to recreating some of these looks.
You’ll probably have to end up using a combination of many different effects to achieve this.
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
