Activity Forums Maxon Cinema 4D Planetary Glow
  • Planetary Glow
    Posted by Thad Ciechanowski on December 18, 2008 at 1:40 am
    HI,
    I’m trying to get a planet (earth) to have a multicolored glow around it like an atmosphere. I also want the glow to be separate so that I can control it, make it less opague in the center, etc. I tried making a material with a slightly larger radius but I can’t get the edges to be more soft. It’s just looks very plastic.
    I tried using a composite tag, but I’m not sure I used it right because nothing seemed to happen.
    I’m still pretty new at C4D but any thoughts would be greatly appreciated.
    Thad
    http://www.dijitmedia.com
    Brian Jones replied 17 years, 9 months ago 3 Members · 10 Replies
  • 10 Replies
  • Nolan Scott
    December 18, 2008 at 2:48 am
    Something like this:
  • Thad Ciechanowski
    December 18, 2008 at 2:55 am
    Something like what?
  • Nolan Scott
    December 18, 2008 at 3:04 am
    Well, I guess you were so fast responding, couldn’t even edit my post…?
    Anyway, if you like, please download the project-file – planet.zip – from my iDisk:
    https://homepage.mac.com/nolan.scott/
    Cheers
    Nolan
  • Thad Ciechanowski
    December 18, 2008 at 3:06 am
    Thanks Nolan, I’ll check it out.
  • Thad Ciechanowski
    December 18, 2008 at 3:15 am
    Thanks again.
    Forgive me, I’m pretty new, but I can’t tell what you did to get the glow. I got rid of everything except the object and there’s still a glow. How did you do it?
  • Nolan Scott
    December 18, 2008 at 3:17 am
  • Brian Jones
    December 18, 2008 at 3:53 am
    It’s a visible light inside the planet with Illumination turned off – it doesn’t need to light anything it just needs to be visible.
  • Nolan Scott
    December 18, 2008 at 4:11 am
    Open the Planet, you’ll see two Light Objects “Atm.Light” and “Atmosphere”.
    (You might delete the Atm.Light, hasn’t really any functions anymore)
    Select the “Atmosphere” and go to the Attributes-Manager and check Visibility,
    Inner- and Outer-Distance and Brightness are adjusted to the size of the planet.
    (play with Distance and Brightness – check/uncheck Use Falloff)
    I just copied the planet from from an fairly old animation.
    You might have to zoom in or out to see it all, specially in the other views.
    If you like here is the original animation:
    https://web.mac.com/nolan.scott/Gallery/Structure.html
    Cheers
    Nolan
  • Thad Ciechanowski
    December 18, 2008 at 4:16 am
    I’m not sure what I’m doing wrong, but when I put a light inside of the planet, nothing seems to happen. There are so many settings, I’m not sure where to begin.
  • Brian Jones
    December 18, 2008 at 6:37 pm
    Take a look at the light in Nolan’s example, figure out the differences in settings between that and a default light (not that many really) for starters
