Activity › Forums › Maxon Cinema 4D › Plane with a material with an alpha channel doesn’t render
  • Emir Bojorquez
    November 8, 2014 at 9:26 pm
    -It could be your scene file, so try copy and paste your objects in a new scene.
    -It could be your Render Options, make sure your option inside render settings has Textures on.
    Good Luck
    Imagination is the best tool…
  • Adam Trachtenberg
    November 8, 2014 at 10:44 pm
    Looks like you’re using a Cinema material with VRay. Use a VRay advanced material instead. Put the alpha in the material weight channel and invert it and put the image in the diffuse 1 channel.
