Activity Forums Maxon Cinema 4D Plain effector position and random weights
  • Plain effector position and random weights
    Posted by Pravin Chottera on November 13, 2017 at 11:34 pm
    This seems super basic, but it’s got me scratching my head…
    I’m using the plain effector to make a bunch of cloned snowflakes fall. I need to ramp the speed of the snowflakes, which is why I’m using a plain effector vs particles.
    Now I want the snowflakes to fall at different speeds, so I put a random effector with random weight above the plain effector.
    But instead of falling at different rates, the snowflakes positions are offset, but they move the same speed.
    How can I have the snowflakes fall at different rates?
    file: 11854_snow.c4d.zip
    Charles Baez replied 8 years, 9 months ago 3 Members · 2 Replies
  • Adam Trachtenberg
    November 14, 2017 at 5:00 pm
    I think you might be able to get the right effect using the Time effector instead of a Plain effector, or even an Inheritance effector, but the easiest way to do this would be to use a standard particle emitter, using the variation parameter for speed.
  • Charles Baez
    November 27, 2017 at 3:27 am
    You could also check out the Magic Snow plugin..https://nitro4d.com/product/magic-snow-2/
