Activity Forums Maxon Cinema 4D Plain Effector Keyframes into After Effects
  • Plain Effector Keyframes into After Effects
    Posted by Juan Obregon on September 19, 2014 at 10:48 pm
    Hello and thank you for your time
    For simplicity I will use a Plane as an example
    In C4D i have a Plane inside a Fracture Object, to the fracture Object I added a Plain Effector, using the Plain Effector I animated the Scale and the Rotation.
    I added a Compositing Tag to the Plane, set the Object Buffer to 1
    I added an External Compositing Tag, ticked the Create a Solid and made it the same size as the Plane
    I then import this into AE, add this to a comp, set the renderer to Standard Final the Plane is shown and animates as inn C4D.
    Now the issue Im having,
    If I click on Extract Button on the Effect Panel for the c4D layer the solid and the cameras show up but the solid has no keyframes, it won’t animate, I assume that it is because the animation is on the Plain effector and not the Plane.
    Now the question,
    How do I animate the Plane inside the Fracture Object using the Plain Effector and get the keyframes in After Effects?
    Again thank you for your time
    Juan Obregon
    Emir Bojorquez replied 11 years, 12 months ago 2 Members · 1 Reply
  • Emir Bojorquez
    September 19, 2014 at 10:59 pm
    When you use a Mograph object you need to put the External Compositing tag on the Mograph Object not on the object inside, in this case on the Fracture Object.
    Good Luck
    Imagination is the best tool…
