Activity Forums Adobe InDesign placing text in current style
  • placing text in current style
    Posted by Nomis on June 17, 2006 at 2:55 am
    Hello –
    Does anyone know how you place text with the current style? At the moment I’m placing text and the style defaults to times.
    Thanks in advance!
    Nomis replied 20 years, 2 months ago 3 Members · 3 Replies
  • Kelly Johnson
    June 20, 2006 at 11:36 pm
    select an empty text frame and choose the style. Then place the text. It will keep all the bolding/italic and such but apply the font.
    Also, set the main style font before drawing any text frame.
  • Erica Gamet
    June 21, 2006 at 4:56 am
    A couple of questions, first: are you placing type or copying and pasting? What program and format is the original text in? Are you using CS or CS2 of InDesign? Are you bringing text into a text frame with existing text or will starting each text frame from scratch work for you? Thanks…that should point us in the right direction to solve your issue.
  • Nomis
    June 21, 2006 at 6:48 am
    That makes a lot of sense. Thanks. Really should have worked that out myself. Been working the wrong way for months.
