Activity › Forums › Adobe After Effects › Placing text above a path
  • Placing text above a path
    Posted by John Schneider on August 24, 2014 at 4:57 pm
    What happens is that when I set my text to a line, it always appears below the line and never above it. The “Reverse Path” function seems to do the trick but it leaves the text also appearing in reverse.
    So how do I put my text above the path I created using the pen tool?
    John Cuevas replied 12 years, 1 month ago 2 Members · 2 Replies
  • John Cuevas
    August 24, 2014 at 9:15 pm
    Can you post screen grab of your text and the text options, cause no matter what I do, I can’t get my text to be reversed.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • John Cuevas
    August 25, 2014 at 12:02 am
    Also, if the text is just below your path line, you could just add a position animator, and adjust the Y position.
    Thinkck.com
