Activity Forums Adobe After Effects Placing a video into a moving and rotating object
  • Placing a video into a moving and rotating object
    Posted by Joel Espino on August 14, 2012 at 2:31 am
    here is a link to what I am trying to nest my video in:
    https://reels.creativecow.net/film/moving-and-rotating-frame
    The white frame will be replaced with video on this project i am working on. The problem is the if I use parallel tracking mode that white square becomes small, if I use transform tracking mode then the white target offsets. (even though i can select all key frames in the position of that target and line them up it, it will only rotate.
    Please help.
    Andrey Sibiryakov replied 14 years ago 2 Members · 1 Reply
