Activity › Forums › Adobe Premiere Pro › Placing a mask in Premiere from After Effects
  • Placing a mask in Premiere from After Effects
    Posted by Kristine Halmrast on June 30, 2013 at 7:05 pm
    Hei,
    In the video the actor is blinking his eyes every now and then. I want his eyes to stay open during the whole scene. He´s lying still staring into the camera, the only movement is in the madrass. This is a one take, so there´s no option to cut to another picture. I created a mask with his open eyes in After Effects, and imported that one back to Premiere Pro. It´s close to perfect, but I can´t seem to get the the mask 100% in place in Premiere Pro, so his eyes gets a slight jump. A lot of fun, but not what my goal is…
    Is there a way that I can tell the mask exactly where to be? Now I´m just zooming in, trying endlessly to get it into place.
    I´m using Cs6. My work flow has been:
    Premiere Pro: right click the clip -> “replace with after effects composition” ->
    After Effects: Created a mask of his eyes + pressed: “add” ->
    Premiere Pro: placed the open eyes clip over his blinking eyes clip
    Hope someone has an answer to this one.
    Best wishes
    Kristine
    Kristine
    Kristine Halmrast replied 13 years, 3 months ago 3 Members · 4 Replies
  • Ann Bens
    June 30, 2013 at 10:48 pm
    Do the whole eye blinking/mask thing in AE, much more controle.
    When finished export as a lossless file and import into Pro.
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
  • Kristine Halmrast
    June 30, 2013 at 11:41 pm
    Aha, thank you! That wil probably do the trick. I´m new to AE. I´ll let you know how it works out.
    Best wishes
    Kristine
  • Ger Meeuwissen
    June 30, 2013 at 11:53 pm
    Did you try to use 50% opacity on the top layer so that you can see the eyes below?
    Ger Meeuwissen
  • Kristine Halmrast
    July 1, 2013 at 12:22 am
    Yeah, I did, didn´t do the trick. I´m using a mouse, maybe a pen would be more accurate.
    Best wishes
    Kristine
