Activity › Forums › Adobe After Effects › Placing a bunch of comps on a percise triangular grid
  • Placing a bunch of comps on a percise triangular grid
    Posted by Dor Peer on October 28, 2014 at 5:19 pm
    Hello!
    I want to place many copies of the same pre-comp on a precise triangular grid.
    Here is a visual example:
    Is there a way to do it precisely? They don’t have to do anything special but the initial placement should be precise.
    Walter Soyka replied 11 years, 11 months ago 3 Members · 3 Replies
  • Jeff Salman
    October 28, 2014 at 9:20 pm
    Hi dor peer,
    What is the graphic in the precomp that you’re trying to place? B/c – in my mind – the correct approach will depend on what is in that precomp. For ex., in the visual example you gave, if the precomp is one of those dots, then I would do it differently than if the precomp is a triangle made up of three of those dots.
    Let me know and I’ll see if I can help. And maybe you can post a pic of the precomp … that may help in figuring out exactly what you’re trying to do.
  • Dor Peer
    October 29, 2014 at 9:02 am
    The precomp is made of a single dot resembling a small light
  • Walter Soyka
    October 29, 2014 at 6:25 pm
    You could use a grid arrangement script:
    https://aescripts.com/layers2grid/
    https://aescripts.com/gridder/
    You may have to select every other row and offset them.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
