Placed image scaling, rotation info
Hi. I am a photo editor who works primarily in Photoshop. In addition to retouching and color-correction one of my duties is to prep images for various output methods, often offset printing. Projects get handed off to me by designers working in InDesign. I have my own method for sizing images to 100%(adding sharpening, etc) in a late-binding workflow. This involves having designers provide me with a pdf which I then rasterize in Photoshop and size by dragging images into the rasterized file, scaling it and then resize either in Photoshop or using Genuine Fractals. If I knew the file resolution of the placed files, which are often something other than 300 ppi, I would just have designers package the InDesign document and I would look at the scaling factors for each image and size to that. My question is this: Is there a way to generate a report from InDesign with information about scaling, rotation and resolution of placed images? Does anyone have an alternate workflow that is effective. I’ve used my method for years. It works well for the most part and I like to have the ability to “eyeball” the images in place without having to go out of Photoshop. However I would also like an alternative for larger projects. Thanks in advance for any feedback.
