Activity › Forums › Adobe InDesign › Place vector image
Place vector image
Posted by Neil Bradley on August 22, 2007 at 2:56 amNew to In Design and need some advice.
I need to import a logo from Photoshop into In Design and retain the vector data.
The logo is made up of a couple of vector shapes and typography however when I useMike Gondek replied 19 years ago 3 Members · 3 Replies -
Kelly Johnson
August 24, 2007 at 1:50 amYour paths in Photoshop should be present in the Paths palette.
Have you tried placing the actual psd file or is it a tiff or eps file saved with paths?
Are you trying to use one of the paths as a clipping path inside of InDesign or just place the graphic?
It would be more bullet-proof to just rasterize the file and place that copy.
Neil Bradley
August 25, 2007 at 1:01 amIm placing a PSD file with the paths intact. The graphic has two layers the first being typographic and the second a vector shape. I need the graphic to be vector sharp when its printed however I notice that the “type” I directly type into In Design and the type I place in are not of the same quality when I saved the entire file as a PDF ( when I look close up you can se that the placed type is rasterized and the “type” I typed remains crisp.
Playing with the programme yesterday I had more luck placing an EPS.
Thanks for you post. Im pouring over books at the mo to learn this programme and so far Im really pleased with what its allowing me to do however like any new process its proving slow going to start. -
Mike Gondek
September 20, 2007 at 7:14 pmThe answer to your question is within Phothoshop not InDesign. Save a copy of the file as either photoshop PDF or EPS. Both of those formats RIP vector data to postscript printers.
Any smart graphics, shapes layers will reproduce with vector quality. Remember in InDsign to do a option command H to change to high quality view, and your vector items will look SHARP and crisp.
