Activity Forums DaVinci Resolve Plaback problems, just 14fps
  • Plaback problems, just 14fps
    Posted by Manuel Wenger on December 20, 2010 at 1:39 pm
    I just set up my whole MacPro 2×2,26 Quad Intel Xeon from scratch, OS X 10.6.5. internal Raid 0 with 6TB (182MB/s read/write accoding to Speedcheck)Slot 1 GTX 285, Slot 2 RedRocket, Slot 3 GT120, Slot4 Deckling Extreme 3.
    I installed DaVinci 7.0.3. as well as FCP and CS5 on the Machine, updated to the last RedRocket Driver (for Redcine X 351) , latest Decklink and latest Cuda driver, but i still get a performance of 14fps for ProRes4444 or 422HQ as well as R3D Files with half debayer good.
    Even my MacBookPro ist faster with ProRes4444 (18fps).
    I can see all 4 installed cards in the System Profiler and they seem to work fine.
    Redcine X with Rocket plays fine and FCP with Decklink HD also is fine, just with DaVinci i´m stuck with 14fps if i turn on video out in the preferences, if turned off i get 21fps playback.
    I tried to reinstall 7.0.2. but still just 14fps.
    would be great if somebody could help.
    thanks in advance
    Manuel
    Manuel Wenger
    DOP / DIT / Digital Colorist
    Munich – Germany
    Michael Cinquin replied 15 years, 9 months ago 3 Members · 3 Replies
  • Christopher Tay
    December 20, 2010 at 3:32 pm
    Try swap the slot position between the REDRocket and GT120 and see if the playback speed improves in Resolve.
    -chrispy
  • Manuel Wenger
    December 20, 2010 at 4:28 pm
    Nope, didn´t help. just tried that.
    A support person from DaVinci just took a look at my Mac remotely and couldn´t find the issue.
    One thing might be, that i have a nvida Geforce 8800 installed instead of the GT120 fur the GUI, but it did work before.
    So, i´ll go and get the GT120 and hope that it solves the issue.
    Manuel
    Manuel Wenger
    Munich – Germany
  • Michael Cinquin
    December 20, 2010 at 6:02 pm
    I would suggest using https://www.macupdate.com/app/mac/32555/cuda-nvidia-gpu-benches to bench your cuda capabilities, and see if the CUDA / graphic card / driver combination works okay. After downloading the app, in the terminal, run _nbody with the -benchmark otption
    With the gtx 285, you should have something like
    540.359 GFLOP/s at 20 flops per interaction (that’s what I get here)
    good luck
    Michael Cinquin
    Final Cut Pro – Avid Media Composer editor
    DaVinci – Color – Baselight colorist
    http://www.michaelcinquin.com/tools : tools for FCP | Color | RED | subtitles | Cinema Tools | Timecode – Keycode calculator
