Activity Forums Maxon Cinema 4D PLA Keyframes
  • PLA Keyframes
    Posted by Tom Slattery on January 9, 2008 at 2:20 am
    Howdy!
    I am trying to animate both the position of a point of a bezier spline as well as it’s tangent handles. I noticed that (with auto-keying on) that it records the first modification (position), but not the second (handles).
    Is that right? Do I need to add a parameter track or something?
    ~TPS
    Tom Slattery replied 18 years, 8 months ago 2 Members · 2 Replies
  • Nolan Scott
    January 9, 2008 at 3:25 am
    Well, works perfectly here.
    Select Point Level Animation, select Automatic Keyframing.
    At frame 0 move your points and adjust the handles / move your time-slider to frame 20 /
    adjust the points and handles again / move your time-slider to frame 50 / adjust points and handles again / go on and set more keyframes if you like / play your animation.
    Cheers
    Nolan
  • Tom Slattery
    January 11, 2008 at 2:37 pm
    I have done exactly that. The only thing getting recorded is the point’s position. If I go back to a recorded frame and adjust the handles, they revert back to where they were before when I click out of it. Weird!
