Activity Forums Apple Final Cut Pro Legacy Pixellated export
  • Pixellated export
    Posted by Ben Hartley on September 16, 2013 at 2:57 pm
    I know this is a common problem on these forums but I cannot work out how to solve the problem. Below is what it should be and what it is exporting as. I have the sequence set to Pro Res lt as is the footage within.
    If you click on the images you can see the difference more clearly.
    If it looks good, look at it.
    Ben Hartley replied 12 years, 11 months ago 2 Members · 4 Replies
  • Ben Hartley
    September 16, 2013 at 3:23 pm
    Also my sequence is at 1080 with 100% render quality and Square pixel aspect ratio.
  • Mark Suszko
    September 16, 2013 at 3:46 pm
    Do you have FCP defaulting to scaling incoming graphics, or leaving them native rez?
  • Ben Hartley
    September 17, 2013 at 9:11 am
    Where do i check if its scaling incoming graphics?
  • Ben Hartley
    September 17, 2013 at 4:07 pm
    The video I am viewing in FCP is not interlaced.
