Activity Forums Adobe After Effects Pixelization effect
  • Pixelization effect
    Posted by Igor Harmendani on January 16, 2012 at 5:36 pm
    Hello guy, I have a ideia for a video but I don’t know how to do it on AE.
    I want a pixelization effects, how could I explain, it’s like a comp beign build by lots of large pixels.
    I found an example in this video
    https://www.youtube.com/watch?v=sXR4Nt_zGBA&feature=related
    At 0:03, you can see the solids start to fade out its pixels. So, I want to do something like this, but in the reverse way. Instead of fading out, I want them to “build” the comp.
    How can I do it?
    Kevin Camp replied 14 years, 8 months ago 2 Members · 4 Replies
  • Kevin Camp
    January 16, 2012 at 6:05 pm
    a quick way would be to use an existing image or try something like fractal noise to generate a texture. then add the mosaic effect to pixelate it and the threshold effect to make a black and white matte.
    animating the threshold ‘level’ can create the reveal.
    you can use that as a track matte for another layer, or an effect like unmult or set channels (or similar) to key the black out and then add the fill effect to fill the alpha with a color.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Kevin Camp
    January 16, 2012 at 6:08 pm
    actually the easy way is to use block dissolve… doh!
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Igor Harmendani
    January 16, 2012 at 6:19 pm
    I can’t believe the solution was in my Effects and Presets window lolol
    Tryed block dissolve and it was incredibly easy.
    Thanks for your help, Kevin!
  • Kevin Camp
    January 16, 2012 at 6:23 pm
    i totally forgot about that effect too…
    i’ve actually never used it in the many years i’ve been using ae, and after my first response, i started thinking i had seen a block dissolve effect in something i use, and there is was in ae….
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
