Activity › Forums › Panasonic Cameras › Pixelation
  • Pixelation
    Posted by B. L. aladin on July 24, 2005 at 11:47 am
    I have two dvx 100a which i run through a switcher (edirol or Panasonic mx50) then through a svideo distribution amplipher and then into a sony dsr25 and record on minidv. Using this workflow, I get a pixelated picture. I have replaced the cables (which by the way I am using 100 and 200’cable) I have replaced the minidv recorder, I have replaced the switcher. The equipment I havent replaces is the svideo da. Could this be the problem? or is it the settings on the camera? By the way, when I record directly into the dvx100, the picture is exceptional. HELP
    Benton
    BL Aladin
    Director
    OCI/OWO/WBM
    B. L. aladin replied 21 years, 2 months ago 2 Members · 2 Replies
  • Noah Kadner
    July 25, 2005 at 7:01 pm
    Most likely the distrib amp is adding the noise since it’s clearly not on the camera. I’d suggest using a simpler signal path if you want a clean signal.
    Noah
  • B. L. aladin
    July 25, 2005 at 10:11 pm
    Actually that makes lots of sense. I was feeding to signal to a dvd recorder and vhs, so you suggest that I feed the signal individually to each. By the way, there is no pixelation on either the dvd or the vhs.
    Benton
    BL Aladin
    Director
    OCI/OWO/WBM
