Activity › Forums › Adobe After Effects › Pixelating PAL DV video
  • Pixelating PAL DV video
    Posted by Lars Therkildsen on September 8, 2008 at 6:10 pm
    Truly hope you can help me here.
    I just recorded some DV Pal 16:9 footage on a greenscreen. The thing is that AE Cs3 (Mac) seems to pixelate the video. And that’s before I even start to play around with it. A straight export from AE, again no playing around with the data, makes the quality lower or more pixelated.
    The original clip in quicktime says 720×576 (768×576). The one out of AE says 720×576 (1024×576). I’m aware that the 1024 part is due to the video being anamorphic. But it seems like AE might be transforming the video to 720 pixels?
    Anyway, I get no loss in data/quality if I throw the footage into Final Cut, and I can’t recall having experienced this before. And yes i am displaying full quality and rendering in dv pal 16:9 25fps, best qual.
    I’ve taken some screenshots of an area from the footage that shows the problem.
    First, quicktime and great qual:
    https://www.gostil.dk/quicktime.png
    Second, export from AE
    https://www.gostil.dk/ae-export.png
    Thrid, preview in AE
    https://www.gostil.dk/ae-preview.png
    What do you think the problem is?
    And thanks in advance!
    Lars Therkildsen replied 18 years ago 2 Members · 3 Replies
  • Lars Therkildsen
    September 8, 2008 at 7:30 pm
    Okay I have now managed to fix this situation. I threw my dv footage into FCP and exported it as Animation, and that makes AE display it in full quality. But still what is happening?
  • Chris Wright
    September 8, 2008 at 8:15 pm
    Check your interpret fields and best edges, resolution, and export settings. Here’s the rundown…
    D-1 PAL -Discreet edit* PAL
    Frame size: 720 x 576
    Frame aspect ratio: 4:3
    Pixel aspect ratio: 1.067
    Frame rate: 25 fps
    Field order: upper field first
    PAL Video Frame size: 768 x 576
    Frame rate: 25 fps
    Field order: lower field first
    PAL-DV Frame size: 720 x 576
    Frame aspect ratio: 5:4
    Frame rate: 25 fps
    PAL-DV Widescreen
    Frame aspect ratio: 16:9
    Pixel aspect ratio: 1.422
    Frame rate: 25 fps
  • Lars Therkildsen
    September 8, 2008 at 8:34 pm
    Ah thank you very much. AE interpreted the footage as lower field first, I set it to off and everything is fine. Again Thanks!
