Activity Forums Adobe After Effects Pixelated Wipe
  • Pixelated Wipe
    Posted by Ray Oliver on October 5, 2016 at 7:25 pm
    I’m trying to make a Pixel Wipe transition. I tried using the block dissolve with a gradient layer but the result is not what I want. I really like what I managed to do with the card wipe but I don’t want the blocks to flip (cause it breaks the “pixel look”). It seems to work if I do it fast enough on a small shape cause the flip is so fast that it just does not flip (it flips in 1 frame) but I’d like to do it on the entire screen and I can’t find a way to stop the flips of simply speed it so fast it’s not visible.
    Could someone help me? Any bit of advice?
    Gertsch Brunner replied 3 years, 2 months ago 3 Members · 4 Replies
  • Kevin Camp
    October 5, 2016 at 10:21 pm
    not sure exactly how you are wiping/disolivng (directional, like left or right, or something different altogether), but you might be able to use a gradient/ramp and mosaic to create a gradient to use with gradient wipe… (remember to pre-comp the gradient and move all attributes before you can use it with the gradient wipe effect).
    done right, you can get the blocks to dissolve away (rather than flip) in the order that you want.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Ray Oliver
    October 7, 2016 at 2:39 am
    Thanks for all you asnwers but it’s not quite what I’m looking for…
    I’ve managed to make something that’s pretty much what I want but you can still see the flipping if you look carefully.
    10658_pixelatedwipe.aep.zip
    In this example, I made the wipe come from both left and right
  • Kevin Camp
    October 7, 2016 at 3:43 pm
    this is pretty similar to your wipe but using gradient wipe.
    10664_10658pixelatedwipecc12.aep.zip
    to change the pixelation, change settings in the gradient map comp. for example, to make the wipe go from left-right, hide or remove the colorama effect. changing the ramp start and end points will further change the direction. modifying the fractal noise effect will change the pixelation pattern (you can actually animate the evolution property for some interesting effects). and changing mosaic will effect the size of the pixels.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Gertsch Brunner
    July 10, 2023 at 4:09 pm
    diggin this thread up again, do you guys still have the files you posted by any chance?
    The links don’t work anymore unfortunately
