Activity Forums Adobe After Effects Pixelated vector art in After Effects
  • Tudor “ted” jelescu
    May 15, 2011 at 10:15 pm
    Do you have the collapse transformations/continuously rasterize box checked on all layers with vector art?
    https://help.adobe.com/en_US/AfterEffects/9.0/WS3878526689cb91655866c1103906c6dea-7f49a.html
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Zack Mulvaney
    May 15, 2011 at 11:54 pm
    ahhh — looks like that was the problem. thank you much
  • Zack Mulvaney
    May 17, 2011 at 4:13 am
    Uh oh — still having the problem… even with continuously rasterize checked. Any other ideas?
  • Don Baker
    March 30, 2014 at 4:07 pm
    I am having the same trouble, but I do have the continuous rasterize icon selected in everything including my precomps. These are imported .ai flat vector images, so I should get perfectly clean edges, especially on straight lines. But I am getting rasterization still. Any ideas of what I can try ?
    Thanks, Don
    donbaker@seanet.com
  • Todd Kopriva
    April 1, 2014 at 12:20 am
    Show screenshots of your Composition panel and Timeline panel, Don.
    After Effects team blog
  • Ruben Vermeulen
    June 9, 2014 at 3:29 pm
    I’m also havin trouble with pixelated vectors in After Effects when I scale objects.
    Continuisly rasterize switch doesn’t make any difference.
    Any ideas?
    Ruben
  • Michael Szalapski
    June 9, 2014 at 3:56 pm
    If you have the switched turned on for a precomp, it’s the collapse transformations switch. If you have it turned on for vector art, it’s the continuously rasterize switch.
    Basically, if you have it on for a precomp containing vector art, you need to also have the switch turned on for the vector art inside the precomp.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Ruben Vermeulen
    June 9, 2014 at 4:01 pm
    Thank you very much! 🙂
  • Michael Licavoli
    August 20, 2014 at 12:47 am
    (I apologize in advance if I’m unintentionally breaking any forum rules as a newb.)
    I’ve tried everything listed here but I’m still having pixelation issues. I have the Document Raster Effects Settings at 300 ppi from illustrator, I’m importing as Composition – Retain Layer Size, and I have the continuously rasterize box checked.
    I’ve attached an image to show what it looks like.
    Thank you
  • Michael Szalapski
    August 20, 2014 at 3:08 am
    Your comp viewer is set at 200%. After Effects will only ever show you the exact pixel value of a comp. If you put your comp viewer at 100%, it will look crisp again and you can scale that up to your heart’s content. 🙂
    – The Great Szalam
