Activity Forums DVD Authoring pixelated travellings
  • pixelated travellings
    Posted by Tiago Bartholo on October 12, 2010 at 8:30 am
    Hi all,
    I am having a problem creating a DVD for a documentary. I have exported it with final cut with with the following settings: h264 and the dimensions of a DVPAL recording (720×576). The thing is, it works fine when I play it out on my computer, but once I record a DVD, there must be something that is done while encoding that just turns the travelling images into heavy pixelated art.
    I have tried re-exporting it with different settings and the pixelated bits do not happen when I exported the video with its current settings as QuickTime movie, but the image quality is much worse…
    I don’t know if I should try another burner, since Toast doesn’t actually give many encoding options, it just does it for you. I’m a little stuck and would appreciate any sort of help or guesses.
    Thank you,
    Jakob
    Tiago Bartholo replied 15 years, 10 months ago 2 Members · 2 Replies
  • Eric Pautsch
    October 12, 2010 at 11:01 am
    You never want to export out H.264 for use in DVD. Its a highly compressed delivery codec, not a mastering one. Export out uncompressed and encode that.
    There’s been too much hype about H.264. Its a very efficient format for certain purposes. It should NEVER be used within any Post Production workflow! Only for delivery (ie. the web, Blu Ray, ect)
  • Tiago Bartholo
    October 12, 2010 at 12:27 pm
    Ill try that. Thanks.
