Activity › Forums › Adobe After Effects › Pixelated text
  • Pixelated text
    Posted by Avrohom Kohn on August 27, 2006 at 5:22 am
    Regular text in After Effects comes out bitmaped in a final hi-res qt movie. Settings: Best quatlity, DV NTSC. Is there a setting I’m not aware of? How can I get sharp text in a final render?
    A.N.
    Joshua Ferg replied 20 years, 1 month ago 4 Members · 3 Replies
  • Filip Vandueren
    August 27, 2006 at 2:28 pm
    Perhaps you’re not viewing the DV quicktime in high quality (in Quicktime player), or a de-interlaced version of it (interpreted as lower field first in AE) ?
  • Patrice Gautot
    August 28, 2006 at 8:06 am
    If you are working with AE 7, in your render settings, maybe uncheck the “use open GL renderer”
  • Joshua Ferg
    August 28, 2006 at 5:42 pm
    Check your view settingings inside the master comp your rendering from. They’ll render out as set.
