Activity Forums VEGAS Pro pixelated text in Sony Vegas 8
  • pixelated text in Sony Vegas 8
    Posted by Damian Turner on November 14, 2008 at 11:28 pm
    I’m having a problem with text pixelating when I render video files out of vegas. Whether the text is generated in vegas or imported from an external source, I keep having this problem. Even when I create outlines in illustrator, I get the same effect. Is there anything I can do to stop this from happening? Also, I heard something about having to use square pixels as opposed to 0.1 or 1.2; is this the case, or do I just need to make sure that the document in which the text was created matches the settings I’m using in vegas?
    Mike Kujbida replied 17 years, 10 months ago 2 Members · 1 Reply
  • Mike Kujbida
    November 15, 2008 at 1:06 am
    What’s your source material?
    Do your project properties match your source material?
    What format are you rendering to?
    What kind of font are you using?
    One trick I learned a long time ago (thanks Spot!!) is to double the size of the text in the frame size boxes in the text event.
    That is, if your project is 720 x 480 (SD NTSC), double it to 1440 x 960.
    There’s a great article here on the Cow called Great Titles with the DV Codec that I suggest reading as the aouthor points out a lot of common pitfalls.
