Activity Forums Apple Final Cut Pro Pixelated frames occurring randomly in clips
  • Pixelated frames occurring randomly in clips
    Posted by Carl O’loughlin on October 15, 2017 at 3:46 am
    Many thanks for the daily posts, a real resource for a newbe to fcp 10.3
    I’m having issues pixelated or distorted frames (sample attached), appearing in both the viewer and any output. Sometimes 3 or 4 or these frames per clip but usually just the one.
    Would anyone have any ideas how to stop this happening? I’ve checked all my source files and they are fine.
    Many thanks – Carl
    Carl O’loughlin replied 8 years, 10 months ago 2 Members · 4 Replies
  • Noah Kadner
    October 15, 2017 at 7:43 pm
    That looks like a corrupt clip. Try transcoding entirely to a ProRes version and see if the blocking persists.
    Noah
    FCPWORKS – FCPX Workflow
    FCP Exchange – FCPX Workshops
    XinTwo – FCPX Training
  • Carl O’loughlin
    October 16, 2017 at 8:34 pm
    Hi Noah and many thanks for your take on this issue
    I’m not totally familiar with the terminology in
    your reply so perhaps you could clarify?
    My process was to extract the clips from an
    AVCHD file and convert them to .mov clip with
    Wondershare converter, trimming each clip as I went.
    I then imported into fcp 10.3. Up until the import
    all clips were fine.
    The “blocking” became evident in the timeline and viewer
    during the editing process and persisted whatever
    “sharing” format I used.
    So If you could explain “transcoding” , what
    stage it should be done and how to achieve it,
    I’d be most grateful.
    Cheers
  • Noah Kadner
    October 17, 2017 at 3:26 am
    Yeah I would guess Wondershare added those glitches. Where did the files come from originally?
    Noah
  • Carl O’loughlin
    October 23, 2017 at 11:43 pm
    Files originally from Panasonic HC-MDH2, which produces AVCHD files.
    Re Wondershare, the .mov filed resulting from a pass thru Wondershare Converter played without issue in QuickTime. It was only after importing into fcp that the corrupted frames appeared.
