Activity › Forums › Adobe Premiere Pro › Pixelated exported After Effects and text in CS3 Premiere
  • Pixelated exported After Effects and text in CS3 Premiere
    Posted by Mike Canella on September 29, 2008 at 4:47 pm
    I am having trouble with some videos I created in After Effects and Live Type. When I bring the AE video into Premiere as a .mov it becomes pixelated. I’ve watched it in quicktime after the export from AE and the playback is sharp.
    Second, I have made credits in live type that also become pixelated when brought into Premiere…
    Is this a setting in Premiere I can change or am I stuck with shotty looking videos/animations? I looked into checking/unchecking the optimize stills in the project settings and have had little luck going that route. Any help would be very helpful!
    Mike Canella replied 17 years, 11 months ago 4 Members · 19 Replies
  • 19 Replies
  • Ann Bens
    September 29, 2008 at 9:29 pm
    Still pixelated after rendering?
  • Mike Canella
    September 29, 2008 at 10:17 pm
    Unfortunately, yes.
  • Vince Becquiot
    September 29, 2008 at 11:02 pm
    First I would check your pixel aspect ratios. After Effects by default works in Square Pixels.
    If you are bringing that into say a DV Widescreen (1.2) or DV (.9) Premiere project, the footage coming in is likely to be ineterpreted to the project PAR (thus pixelation).
    Right click on the clip, choose interpret footage and make sure it is set to 1 (if that’s indeed the ratio you were working with in After Effects)
    Vince Becquiot
    Director | Editor
    Kaptis Studios
    San Francisco – Bay Area
  • Ann Bens
    September 29, 2008 at 11:17 pm
    Check your field order in AE. Should be the same as your project settings.
  • George Shubin
    October 15, 2008 at 10:30 pm
    I am wondering if you ever got a solution to this problem? I too have recently discovered this problem with my CS3 PPro footage. It doesn’t matter what type of footage it is – I’ve rendered out uncompressed, animation QTs, DV, whatever, they look great when I reimport them into After Effects. But once they are on a time line they look like crap.
    To describe it, at first glace you would assume a field issue, but playing with the field options produces no solutions (with the exception of the ‘Flicker Removal’ option which minimizes the issue but doesn’t solve it (and besides then you have to render out the clip). I doesn’t matter how the original clip was rendered out either, be it progressive, upper first, or lower first it is the same result.
    At first I thought it was a codec issue. So I created a new PPro profile to use uncompressed footage. Same issue.
    I’m at my wits end on this. If I save a frame out from the timeline it renders these errors and are quite obvious. So it is not just a display issue.
    Any help would be appreciated.
    BTW – my system: WinXP, 4gig RAM, Matrox RT.X2, Matrox Parhelia APVe display card
    George Shubin
  • Vince Becquiot
    October 15, 2008 at 10:33 pm
    Could you give us some concrete examples? Format, codec, pixel aspect ratio, resolution?
    Vince Becquiot
    Director | Editor
    Kaptis Studios
  • George Shubin
    October 15, 2008 at 10:40 pm
    sure, I just trying to do regular NTSC DV using the standard presets from Adobe both in AE and PPro. I’ve tried using the Microsoft DV codec, QT Animation codec, Uncompressed AVI, Uncompressed QT, progressive, lower first, upper first, square pixel, 0.9, 1.2 aspect ratio – these all have the same results.
    If you preview them in Media Player they look fine. If you reimport them into an AE timeline they look fine. It is just when they go onto a PPro timeline that they look weird.
    George Shubin
  • Mike Canella
    October 15, 2008 at 11:08 pm
    Sorry for the delays guys…
    But I still have not been able to resolve this issue! It will not work like you have mentioned whether it’s been rendered, compressed, or whatever.
    I am working on an iMac but I do not think this is causing a problem. I know they work in different pixel shapes but I’ve tried adjusting for that and it doesn’t work either.
    I resolved the problem with the credits in the clip by replacing it with title slates in Premiere… But the .mov I’ve exported out of AE still looks awful once brought into PPro
    Here is the clip once exported out of PPro (with the old ugly credits)
    https://www.jma.duq.edu/users/canella/pub/videoLinks/videoAEoutro.htm
    I don’t think this is a setting in AE either. The credits were originally created in LiveType… so the problem has to be coming in Premiere.
  • Vince Becquiot
    October 15, 2008 at 11:47 pm
    About 90% of the time, pixelation is due to a wrong Pixel aspect ratio somewhere in the chain. Let’s take a specific file here.
    What was the Pixel Aspect Ratio in the file brought into AE ?
    What are the composition settings in AE?
    What are the export settings in AE?
    Once imported in Premiere, right click on the clip, interpret footage. What are the settings ?
    BTW, Premiere often wrongly interprets the pixel aspect ratio coming from AE.
    Vince Becquiot
    Director | Editor
    Kaptis Studios
  • Mike Canella
    October 15, 2008 at 11:50 pm
    I am away from my machine right now but I will absolutely check this and get back to you tomorrow at some time…
    Thanks for your help!
