Activity Forums Apple Final Cut Pro Legacy pixelated captures!
  • pixelated captures!
    Posted by Johnnyboy on October 20, 2005 at 7:06 pm
    please help!
    i recently shot a short piece on a sony 3 chip camera…its on mini-dv, watching it on a tv from the camera, it looks smashing.
    the video itself is a still shot of a person, and slowly lights around them change from green to red.
    when i try to capture it, it immediately seems very pixelated, getting much much worse as the image becomes red.
    ive checked presets and everything, and as far asi know i have it set right (DV NTSC 48hz), etc.
    i have trouble with final cut, so if its something easy please tell me! is there some sort of uncompressed setting i need to capture with? when i watch the captured files in Quicktime at their original size, the pixelation is even worse.
    help!
    Chris Dickinson replied 20 years, 11 months ago 3 Members · 6 Replies
  • Bouncing Account needs new email address
    October 20, 2005 at 9:25 pm
    You must only judge quality on an external video monitor and not on the computer monitor.
  • Johnnyboy
    October 20, 2005 at 9:52 pm
    thats good to know! i will do that
    however, it is VERY pixelated more than just a little janky. there are jagged lines where there should be smooth ones. there are visible pixel blocks surrounding the red lights (which are visible in frame).
    October 21, 2005 at 10:24 am
    What are your capture settings?
    Easy Set-up: DV NTSC (or DV PAL, if that’s where you are)?
    Are you in “Off-line JPEG” mode?
  • Johnnyboy
    October 21, 2005 at 4:55 pm
    DV NTSC
    im not sure what offline JPEG means, where is that setting?
    October 21, 2005 at 7:19 pm
    [johnnyboy] “im not sure what offline JPEG means, where is that setting?”
    Its called “OfflineRT NTSC” under “Easy Setup”.
  • Chris Dickinson
    October 22, 2005 at 7:27 am
    I’ve just come across the same problem.
    Shot on DVX 102a – digitized in FCP 4.5, PAL DV settings. footage is a nightclub and FCP seems to be having problems with extreme chroma – areas where there is heavy red or blue go pixelated. NB this is a localised effect – pixelation only occurs around the most extreme chroma areas… Can’t find a fix – have played with settings… Can’t figure it out!
    Help!?
    Chris D
    Chris Dickinson
    Lighting Cameraman and Editor
    http://www.chrisd.tv
