Activity › Forums › Adobe Photoshop › Pixelated Brushes
Pixelated Brushes
Posted by Mike Moon on January 13, 2010 at 8:04 amHello all,
I have a problem here with my photoshop. And I can’t for the life of me figure it out. My brushes are all pixelated. No matter what brush I use, they all have a pixelated edge
Rajesh Lathi replied 12 years, 10 months ago 4 Members · 4 Replies -
Mike Moon
January 13, 2010 at 8:13 amafter a lil searching around i found a website that just told me to delete the photoshop preferences so it just resets photoshop. And no you won’t lose your plugins or brushes etc.
1) Close Photoshop, and 2) Hold Command + Option + Shift (Control + Alt + Shift, PC) while you restart Photoshop.
boom, pixelated brushes are gone.
if anyone knows WHY the pixelated brushes even happen, I’d love to hear it!
Keith Carmichael
January 17, 2010 at 3:32 amYou have of course checked that you’re not using the pencil tool by accident.
Tharon Carlson
September 15, 2013 at 11:58 pmI had the same problem. I was definitely using the brush tool. I finally found this post and although I had to reload my brushes after following the solution above, it did work! So thank you thank you! I would also like to know what the problem was so if it happens again I can directly fix or avoid in the first place.
Rajesh Lathi
November 4, 2013 at 11:10 amits happen into me also ..and yeah u might be select pencil tool.. accedently .. or check ut brush mode it might be in dissolve mode.
