Activity Forums Apple Final Cut Pro Legacy Pixelated, Blurry Text
  • Pixelated, Blurry Text
    Posted by Heringji on September 28, 2006 at 3:46 pm
    I added to my sequence using Final Cut Pro also, I used the font Impact and changed the color to light purple, added some movement to it. It shows up as looking wonderful before I render it. Then after I render it, it looks horrible. All blurry or pixelated. I tried using the anti-alias effect with it’s range set on 1. That also looked bad. Any suggestions?
    Shane Ross replied 19 years, 12 months ago 2 Members · 2 Replies
  • Heringji
    September 28, 2006 at 4:04 pm
    I searched through the archive posts and my questions had already been answered before. I put my render settings on “Full”, and then I watched my sequence play on a tv monitor. Looks fine. I wonder why it looks so bad on Final Cut. Hmm…
  • Shane Ross
    September 28, 2006 at 4:10 pm
    Shane’s Stock Answer #2: Blurry playback
    ONLY JUDGE THE QUALITY OF YOUR MATERIAL ON AN EXTERNAL NTSC MONITOR, OR AT LEAST A TV.
    1. Disable overlays on the canvas
    2. Make sure you’ve rendered everything (no green bars at the top of the timeline
    https://docs.info.apple.com/article.html?artnum=24787
    Video playback requires large amounts of data and many computations. In order to maintain frame rate and be viewable at a normal size, only about one-fourth of the DV data is used in displaying the movie to the screen. However, the DV footage is still at full quality, and is best viewed thru a TV or NTSC monitor routed thru your camera or deck.
    Shane
    Littlefrog Post
    http://www.lfhd.net
