Activity Forums Maxon Cinema 4D Pixel sorting effect in C4D
  • Jim Scott
    June 27, 2016 at 10:32 pm
    Check this out:
    https://vimeo.com/149650599
    He apparently uses animated displacement maps created in AE using Pixel Sorter.
    Hope this helps.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Fabien Rx
    June 27, 2016 at 11:32 pm
    Hey Jim,
    Thanks for your answer! But i’m not sure about how to achieve this..
  • Jim Scott
    June 27, 2016 at 11:54 pm
    You might try contacting the author and see if he can give you more information about his technique.
