Activity Forums Adobe After Effects pixel size text problems
  • pixel size text problems
    Posted by Andrés Borghi on July 23, 2013 at 8:59 pm
    Hello!
    I’m working on a video where a facebook-similar page is shown and we have to recreate facebook on ater fx.
    The problem comes when adding the text. I’ve found some pixelated looking fonts but when I scale them to “facebook size” they distort. I guess they are 10 or 11 pixels high. If I activate the icon that adds antialias to the layers (don’t know the actual name of the feature, sorry, it’s the one that has this bar “/” ) It makes it too blurry. And If that’s not activated the pixels mix and the text gets distorded. I’ve tried many sizes but it’s always the same.
    I wonder if there’s a correct way of doing this. The text really has to have the facebook size. Can’t be made bigger.
    Cassius Marques replied 13 years, 1 month ago 2 Members · 5 Replies
  • Andrés Borghi
    July 24, 2013 at 12:42 am
    I’ll try to make it more clear.
    My composition, which mimics a cmputer screen where the user is using facebook, must be exported as a full video in 1920 x 1080. it’s like making a screen capture of your pc right now, if were using facebook. later, the camera will make extreme close detail shots of the things people write in facebook, filming the screen of a real monitor.
    So, I just need to imitate facebook, that’s all.
    But when I make the text the size needed (it’s the same exact size you’re reading right now) the text gets blurry.
    That’s the problem. If I lower the quality of the layer to avoid antialiasing so it remains pixelated, the text gets distorded. So, The ideal outcome would be to have the text perfectly pixelated just as the one you’r reading here, but I just can’t get to make it look like this.
  • Cassius Marques
    July 24, 2013 at 2:36 pm
    I can’t understand what you’re after. You’re contradicting yourself.
    [Andrés Borghi] “If I lower the quality of the layer to avoid antialiasing so it remains pixelated”
    If you try to avoid antialiasing, yes text will become pixelated/aliased.
    But then you say:
    [Andrés Borghi] “The ideal outcome would be to have the text perfectly pixelated just as the one you’r reading here”
    A text rendered by a browser ain’t pixelated (is doesn’t look as it, because you don’t see the pixels) because it is antialiased!
    So if you want to allways have a render perfect text, just do as Dave said and check “collapse transformations” for any composition that has a text layer inside.
  • Andrés Borghi
    July 24, 2013 at 5:41 pm
    Hmm, ok, I’ll try with an image to illustrate my point. The text is NOT on a precomp, so collapse is not allowed. The text is right there in the main composition.
    So, here it is:
    Here, you see the text “El Cicho”, 3 times, one after another.
    1-the first “El Cicho” is a jpg, a capture directly taken from facebook, so you can see how perfectly defined the pixels are. This is how I have to make the AE text look like.
    2-The second “El Cicho” is a text layer from AE where I tried to get it to look just like the first “El Cicho”. As you can see in the layers below, this one has the “quality” feature ( “/” ) activated. The text looks blurry.
    3-the third one is the same as the second one but in draft quality. You can see the pixels are well defined but the text is distorted.
    So, I can’t get it to look like it should. Maybe I’ve reached some limit of the software…
  • Andrés Borghi
    July 25, 2013 at 4:26 pm
    it’s the same
  • Cassius Marques
    July 25, 2013 at 5:28 pm
    What you want is a very specific scalling algorithm (like the one controlling viewport magnification that you used as example), there’s nothing font or quality related there. Nor thats an application limitation, no one would ever be able to make fonts render in “n” ways considering “n” scale values. That alone is an application by itself.
