Activity Forums Adobe After Effects pixel ratio query
  • pixel ratio query
    Posted by Chris Brett on September 21, 2012 at 2:25 pm
    Hi there
    Bit puzzled witH some pixel ratio issues and any tips on this would be much appreciated.
    1 ) In AE if the end job is PAL wide-screen what are the correct settings please? — is it 1024 x 576 / pixel width 1.46 ?
    2 ) If a project has been built in ‘square pixels and it should be 1.46 whats the quickest way to sort this do you reckon please? ….
    ….. I imagine one adjusts the comp settings then rebuilds bg plate to fit followed by slight re-arrangement of various visual elements to suit as best — loads of work though …..
    3 ) just installed new wide-screen monitor and projects that ‘look right’ still are not quite correct till comp settings are changed to PAL 1.09 !!!!
    At the minute I just dont get it — they all looked fine before ….
    ….. maybe theres some kind of software setting on the new monitor ?
    Its connected to the PC via a USB lead ( as well as the DVI lead ) and theres a software disc to load which am planning to do later on today…
    ………. coffee break required I think ………..
    Chris Brett // UK
    Chris Brett replied 13 years, 11 months ago 3 Members · 5 Replies
  • Kevin Camp
    September 21, 2012 at 3:09 pm
    Hi Chris, I’m not in front of ae today, but I think 1024×576 is pal widescreen square pixel… I think pal widescreen 1.46 par would be 720×576. Double check in the comp presets for pal.
    To convert one par to another, if you should just need to drop the square pixel comp into a nonsquare pixel comp. ae should handle the conversion. It’s actually a fairly common way to work in ae.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Chris Brett
    September 21, 2012 at 3:40 pm
    Hi Kevin
    — much appreciated — yes — I’m sure you are right without even checking — seems pretty obvious now you say it — 1.46 is PAL anamorphic right ?
    — all the best ——– Chris Brett
  • Kevin Camp
    September 21, 2012 at 4:00 pm
    Yes, 1.46 would be anamorphic.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Jon Bagge
    September 22, 2012 at 7:28 pm
    PAL square pixel is 1050×576. This got changed from 1024 a few years ago. All the Adobe presets uses 1050. If you’ve done it 1024 already it shouldn’t matter too much.
    https://www.jonbagge.net
    Jon Bagge – Editor – London, UK
    Avid – FCP – After Effects
  • Chris Brett
    September 22, 2012 at 9:35 pm
    thank-you very much Jon — I’ll keep it quiet ! —–chris —
