Activity Forums Apple Final Cut Pro Legacy Pixel ratio import trouble
  • Pixel ratio import trouble
    Posted by Anthony Faulkner on August 14, 2008 at 1:59 am
    I have some footage that was shot on (I believe) wide screen squeeze mode. When i try to import it into FCP4.5 using the NTSC anamorphic preset it refuses to resize it. It show up in the log and capture browser the correct size but when the captured footage comes in, it is in the standard pixel ratio and thus still squeezed. I have also tried to capture using the capture now option to the same end.
    Am i missing something??
    Any advice is greatly appreciated!
    Anthony Faulkner replied 18 years ago 2 Members · 2 Replies
  • Rafael Amador
    August 14, 2008 at 3:45 am
    [anthony Faulkner] “but when the captured footage comes in, it is in the standard pixel ratio and thus still squeezed”
    Where are you watching those clips? With QT player?
    Have a look if in the FCs Browser they are checked on in the Anamorphic column.
    rafael
    http://www.nagavideo.com
  • Anthony Faulkner
    August 14, 2008 at 4:29 am
    Excellent!! something simple!!
    thanks very much!
