Activity Forums Apple Final Cut Pro Legacy pixel problem
  • Posted by David Mayer on June 9, 2011 at 6:13 pm
    I am working with an hour of 16 x 9 SD footage. It’s about 13 GB. I ftp’d the footage to my editor – we use the same version of FCP. I sent it to him as a 640 x 360 quicktime movie so I would not have to send a 13 GB file to him. He emails me back the EDL, I open it up and “reconnect media” to my full size media, naturally, not his 640 x 360 .mov file. Now it looks all blown up, zoomed in and blurry – I assume because of the pixel discrepancy. Solution?
    Dave
    iMac 2.8 GHz Intel Core i7, 8 GB
    OS 10.6.2
    Final Cut Pro 7.0
    David Mayer replied 15 years, 3 months ago 3 Members · 5 Replies
  • Tom Wolsky
    June 9, 2011 at 6:26 pm
    Please give the exact item properties of the clips you’re editing and the exact item properties of the sequence in which you’re editing. Select a clip in the Browser and press Cmd-9 or Edit>Item Properties>Format. Select a sequence in the Browser and repeat.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • Cody Walters
    June 9, 2011 at 6:32 pm
    I would check in the Motion tab to see if the scale and distortion has changed. Sounds like your scale is more than 100%. If so, you could highlight your clips and remove the distortion and basic motion attributes.
    Cody Walters
    JW Studio LLC
    Houston Video Production
    Houston Wedding Videographer
    Final Cut Studio 3
    Adobe CS5 Master Suite
    Panasonic HVX-200
    Canon 7D
  • David Mayer
    June 9, 2011 at 6:48 pm
    Hi Tom,
    Original project:
    Media: frame size 720 x 480
    pixel aspect NTSC – CCIR 601
    Sequence: same as media
    Project I received from my editor:
    Sequence: 720 x 480 and Square
    The Media I sent to my editor that
    he edited with was: frame size 320 x 180
    pixel aspect Square
    And then I reconnected to my original media when
    I opened up his sequence.
    Dave
    OS 10.6.2
    Final Cut Pro 7.0
  • Tom Wolsky
    June 9, 2011 at 6:54 pm
    How did he edit 320×180 media in a 720×480 sequence? Did he media manage it to make it DV size? Please post screenshots of the item properties of your sequence and the item properties of the media you’re reconnecting. If the sequence is 720×480 and the media is the same it should not look as you describe.
    All the best,
    Tom
  • David Mayer
    June 9, 2011 at 7:07 pm
    Tom,
    Sorry – more info:
    when i opened up his sequence, it was:
    1920 x 1080
    Aspect ratio: HDTV 1080i (16 x 9)
    and
    Pixel aspect ratio: Square
    Now the problem becomes more clear – he edited a small clip
    as though it was HD. So I’m not sure why it would have looked OK
    to him with those settings.
    I tried to embed screen captures I made using Grab,
    but those are .TIFF files and not supported. Will have
    to find something else.
    Thanks again,
    Dave
    OS 10.6.2
    Final Cut Pro 7.0
